4 members (Gray_Ghost, rfs56trk, greenie-reddy, Dennys28), 182 guests, and 0 robots.
Topics128,080
Posts1,056,060
Members48,433
#1363627 06/05/2020 6:46 PM
Has anyone successfully transplanted a Detroit diesel in their 1940-46 truck? I was thinking about using a gama goat engine which is a Detroit 3-53 and sm420. While I have the measurements of the engine I’m not sure if it will fit. Length = 33, width =27, and height 39. Seems like a lot but checking the engine bay it looks like o could easily move the radiator forward a few inches and the width of 27 wouldn’t fit between the frame rails, but the max width on a 3-53 isn’t down low, it’s mid block where the blower is.
Anywho, if anyone had swapped in a Detroit already, I’d love to see pics of it!!
Tony292 #1363628 06/05/2020 6:55 PM
PA OUTLAW
PA OUTLAW
l had a friend that put a 353 in 1970 chevy wow!!! could rattle the windows in the neighbor hood ill see if he has any pictures of it
Tony292 #1363630 06/05/2020 7:19 PM
With an approximate usable RPM range of 1750-2150, you're going to need a lot more gears than that SM 420 has. Better add a 3 speed Brownie to give you 12 forward speeds, and do a lot of dumbbell curls with your right arm- - - - -you'll be "rowing it with the shift levers"!
The 53 series has more rpm Range than that, it goes up to 2800 RPM.
Tony292 #1363634 06/05/2020 7:58 PM
Also the engine I’m talking about is the 3-53 from a. Gama goat. The gama goat came with an sm420 trans and it’s max speed rating was 56 mph with a 5.57 gear ratio on 9x20 tires.
My plan would be 5.43 gears and a ranger torque splitter overdrive (28%), with 8.25x20 tires.
Tony292 #1363682 06/06/2020 12:31 PM
ASU Offline
The 3-53 was rated at 101 HP. new. I drove a 1970 3/4 ton GMC with a 3-73 and a SM420 in it. One of the most underpowered, slow trucks I have ever driven. It needed 6 inches of body lift to close the hood. Be prepared to do A LOT of work to make it fit. The detroit "power band" is fairly small, they don't "lug down " well. If you are looking for "slow and loud" then go for it.
Tony292 #1363704 06/06/2020 3:04 PM
Crusing in the Passing Lane
Tony,
At least look for a T engine, since you plan on 20" tires, do you have a 1.5 ton truck you plan on using. Will be pretty gutless on Hills. A 4-53T is too big for your engine compartment.
Ed
EdPruss #1363758 06/07/2020 12:17 AM
That’s what I was thinking. Doing the measurement and comparing to Kline measurements, it looks like only the 3-53 will fit and just barely. It’s hard to find a 3-53T, so I’ll probably do a 3-53N and just add the turbo parts later as I find them.
ASU #1363762 06/07/2020 12:41 AM
I doubt it could get any slower than the current 216... Detroit’s are easy to turn up the power...
Tony292 #1363912 06/08/2020 12:31 AM
Grigg on here did a 4-53T conversation in A-D 2-ton Truck. Others have done it. Search these forums. Also there are some YouTube videos of diesel conversions in old GM trucks. Maybe that will be useful.
Professional Novice
Tony292 #1364267 06/10/2020 3:24 AM
I would look at a Cummins 4bt. I haven't measured it yet but just looking at it, might fit
Kosanow1
Tony292 #1364302 06/10/2020 12:16 PM
Detroit may not be the most powerful, efficient, or easy..... but in my opinion they are the coolest of that generation diesel engine. They will definitely put in work and that sound is just amazing. My good friend just restored a 1968 gmc dump with a 6-71 and I am in love with how it drives and sounds. No other sound like it from a bygone era.
