2 members (dt235sd, Southerntruck), 145 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
#1363243 06/02/2020 8:29 PM
HAS ANYONE SEEN A KIT TO CHANGE OVER TO 22.5 DAYTON WHEELS? I HAVE A 1966 GMC 960, 5 BOLT FRONT AND 10 BOLT REARS 20" SPLIT RIM. FOR YOU YANKS ITS A C40 OR 50? DOWN THERE
What you have would be equal to a C-50. Are you sure you want Dayton's (Spokes)?
I doubt if Dayton's would work anyway.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
My T-50 Steel Tilt Cab has 20" Daytons on it, as I understand they could be converted to 22.5's but it would take a lot of iron.
Everything from the wheel bearings out would be needed as I understand it.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
There were Disc to Dayton adapters made, I have a set for 6-lug Budd to Dayton, but not sure if they made then for your lug pattern or not.
If you have 20" tube type Dayton's the tubeless 22.5's will bolt right on, nothing needs to be changed other than the rims and tires.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Yeah, Mike is right, I failed to re-read what I posted, sorry.
Mac :{)
