1 members (Peggy M), 121 guests, and 3 robots.
Topics128,072
Posts1,055,904
Members48,429
#1361559 05/23/2020 12:03 AM
Jim C. Blue
Jim C. Blue
I was thinking of posting this and Alaska Jim's post encouraged me to do so.
It is on my 53 GMC 3 ton grain truck. I personally find it unusual, as I am use to these old grain trucks having unbranded, under-box hoists. Normally I see this behind cab type on dump trucks.
I did try it and it does work, though the cylinder did leak when it got near the top. Also, should the leaver have a neutral position or do I need to disengage the PTO for that?(hence why the leaver is in the cab.)
Alexander's Automotive Assortment
  • 1953 GMC 9700 3-ton**
  • 1978 Plymouth Arrow
  • 1980 Jeep J10 Cargo Truck
  • 1985 Red Wagon Trailer (for cars)
  • 1986 Toyota Tercel Wagon 4wd
**(9700 in Canada or 450 in USA.)
alex...the pto s ive been around didnt have a neutral not even 2-speed ones my dump truck is a no name too and is either on or off. its tuff can put on 8000 lbs white rock and it will pick it right up...take care of my driveway that gets fed-ex traffic with it. hoist leaked at first around control shsft put a fresh retaining screw in it sealed it right up
Jim C. Blue
Jim C. Blue
Forgot to mention: figured it out and it is why they put the lever in the cab, so you can control both the hoist and the PTO, so you can turn it off when it is high enough.
