| | | Forums66 Topics128,164 Posts1,056,982 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13627 12/04/2003 8:22 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I recently bought an OD transmission. I have all the electronic components but need the bracket to hold the kickdown switch to the carburator, and the tab which connects to the linkage - which the kickdown switch pushes against when the throttle is mashed down to cut off the OD unit.
Does anyone know of a vendor or source to get these items? Does anyone have them and can give me an idea on how to make my own.
Thank you
Dennis -there is nothing stronger than the heart of a volunteer-
#13628 12/04/2003 9:00 PM | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | I run my '62 3sp+od off of a lighted switch on the dash and don't use any of the kick-down or carb. pariphernalia. The important thing to remember is not to start out in overdrive. I assume you've checked it out before installing. Mine is the non-synchro 1st gear model.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#13629 12/05/2003 1:57 AM | Joined: Nov 2002 Posts: 23 Junior Member | | Junior Member Joined: Nov 2002 Posts: 23 | First are you running a I6 or V8? If it's a I6 time to use 2 barrel bracket that's modified or make your own. The best I6 set-up I saw was using a clip off the shifter linkage on the trottle rod to close the switch at the carb.There is a place called C&P Automotive in Kulpsville, PA that might be able to help, the phone number is 800-235-2475.
willy 57 | | |
#13630 12/05/2003 5:30 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Dennis - check the wreckers and look at kickdowns on any later automatic - shouldn't be hard to adapt or fab yer own based on what ya see
Bill | | |
#13631 12/09/2003 4:52 AM | Joined: Oct 2003 Posts: 17 Member | | Member Joined: Oct 2003 Posts: 17 | Check out Bowtie Overdrives. They have everything you need. From what Ive been told the adjustment on this cable is critical! Let me knoe how you make out as I plan to put an overdrive in my 46.
No hill for a climber!
