9 members (cmayna, 49choptop, fonz8261, FrankenChevy, baldeagle, Peggy M, tclederman, TexasJim50, 1 invisible), 49 guests, and 4 robots.
Topics128,018
Posts1,055,341
Members48,419
#1362803 05/30/2020 8:51 PM
One of my oldest friends asked me to come up to his shop he had just helped transport a truck he thought I would get a kick out of. That and the guy who is goi g to redo the truck for the owner, whose family are the original owners of the truck since new, wanted to pick my brain on the motor.
So I made the hour drive and was he right. Look at this truck! When I think wrecker, this is the kind of truck I think about.
Mike
Dragsix #1362805 05/30/2020 8:53 PM
I seem to be having an issue posting the photos. Let me see if I can sort it out.
Mike
Dragsix #1362808 05/30/2020 9:05 PM
I think it’s a 52. I also think it’s a 235 from the valve and side cover. To much junk to grab some casting numbers. Truth be told, it’s a littler earlier truck then I am use to fooling with.
Mike
Dragsix #1362813 05/30/2020 9:16 PM
Nice truck.
"I think it’s a 52"
It looks like it has a turn-down door handle with the vent-window door?
In 1951, the outside door handles were still turn-down type.
If so, 1951 was the only year with vent windows and turn-down handles.
"I also think it’s a 235 from the valve and side cover."
How/why do they make you think that it is a 235 rather than a 216?
Were 216 valve cover and side cover different from those?
Is there a "series" name (Thriftmaster or Loadmaster) under the "Chevrolet" on the side emblem?
Nonetheless, a low-pressure 235 would most likely been used on that type of truck?
Nice truck.
Dragsix #1362854 05/31/2020 2:26 AM
Looks like a Holmes 515...nice find!
Is it going to be restored or maintained?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Dragsix #1362871 05/31/2020 11:24 AM
Bond Villain
Bond Villain
Originally Posted by Dragsix
I think it’s a 52.
Have you seen our Advance Design Spotting Guide?
On the engine, the only thing to tell you if its a (babbitted) 235 rather than a 216 is the casting number. Don't guess, give us the casting number and we'll tell you. smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Dragsix #1362892 05/31/2020 2:57 PM
If you rotate and zoom in on the engine picture you can see a smooth bulge between spark plugs 1 and 2. It also has a short lifter cover. That would be correct only for a 50-52 low oil pressure 235, and the correct original engine for a 50-52 2-ton.
I agree, check all the numbers to be certain.
Very cool old Chevy Big Bolt!!
Professional Novice
Dragsix #1362895 05/31/2020 3:26 PM
Reminder to all.... EBay, Craigslist and other sale/auction links are not allowed in the garage forums. We have a special forum for those. Scroll down!
Dragsix #1362909 05/31/2020 5:30 PM
It has to be restored. The front sheet metal is in extremely poor condition. I think the rust is all that is holding it together. There are other components that make the truck unsafe if not repaired properly and those issues are more then cosmetic. On the other hand, it’s all there and complete. All the winch components, cables, everything. And the wrecker body, with the flat sides and the grab bar, It’s just way too cool.
Mike
Dragsix #1362920 05/31/2020 8:03 PM
I really like the Chariot style wrecker bodies...
Being 100% complete is half the battle...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Dragsix #1363324 06/03/2020 12:40 PM
Looks like pull down door handles ? If so, it's a 51. I can also tell it's a 2 ton, by it having the heavier front axle, with bolt on front dust caps. All 47-53 Chevrolet 2 tons came with the Loadmaster 235 engine. All that said, it looks like you have a 1951 Chevrolet 6100 series, 2 ton, with short wheelbase, medium duty, Holmes Traffic King model 515 Wrecker. Holmes also had a model 460 Speed King, that used that same short Chariot Style service body, but different rear fenders. Should be a Ernest Holmes serial number plate on the passenger side boom mast vertical beam, to verify the model. That's a nice old wrecker right there. I've been collecting Vintage Holmes Wreckers, for many years. Here's the Heavy Duty Holmes model W35, I'm now working on.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Dragsix #1363331 06/03/2020 1:23 PM
I second the engine, a 1950 to 52 235. In Canada they made 216s like that. That truck is a real piece of history.
1951 1 Ton Completed
