7 members (Thomaslb, 1955 1 Series, Hanks custodian, Ridgeback, Hotrod Lincoln, Ponchogl, 1 invisible), 46 guests, and 2 robots.
Topics128,090
Posts1,056,031
Members48,433
I had removed the top cover from my Muncie 420 in order to do a good flushing of the old gear oil and check out the condition of the innerds.
Now for the life of me I can not get the cover and forks to go back on correctly. For instance, sometimes it seems like the cover goes on but won’t shift correctly and neutral is NOT neutral.
Hoping someone has some tips to get the cover back on and forks aligned properly. Thanks for any help.
Crusing in the Passing Lane
Need to make sure it is level so gears don't migrate downhill, get all the gears in neutral, get shifter in neutral, be careful longer forks don't bump a gear into engagement.
Ed
Thanks. Any tips on getting the gears in neutral?
It kinda like a puzzle that Indiana Jones would unlock, but really much easier. You may want to have the rear on jackstands and someone underneath to let cha know if its in neutral while you're moving slids around. Its hard to explain and easier to actually do. Was the truck in neutral when you pulled the cover? Its really a matter understanding whats going on inside. Sounds like one of the forks on the shifter is going behind or infront of the "channel " its supposed togo into to. Especially if you are seeing that neatral is Not neutral. Patients and dont force the cover on.
Second and high(synchronized) have a sliding collar with a groove in the middle for shift fork that need to be in the middle of its range(neutral) , which can be shifted there by hand, screwdriver, etc., first and reverse are sliding gears that have more throw of the Shifter fork. Get the 2nd., high in neutral first.
Ed
Truck is in rebuild stage. Motor and tranny went in this past weekend. No driveshaft yet. I’ll tinker and see what I can do. It’s just a frame, motor and trans right now. Not sure what gear it was in when I pulled it.
Oh. That should make it abit easier. You wont need someone underneath. And you can stand there. Just pay attention to where the forks are going when dropping cover. Make sure they're in the channels.
GOT IT!!!! Thanks for the help team!!!
If you do it again, remember the distance between 1/2 and 3/4 forks is 4-7/16" outside to outside. Move first gear to get that dimension and you are golden.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1321055/re-sm420-help.html#Post1321055
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
I hope I don’t have to do it again..... 😀. But thanks for the tip
