6 members (Bill Hanlon, Donf, MickeyP, Hotrod Lincoln, mick53, FAST55), 109 guests, and 1 robot.
Topics128,049
Posts1,055,701
#1362773 05/30/2020 5:48 PM
Im working on a 54 chevy 3100. Have booth doors off and have windows and door handles and lock out. Have replaced the door closer, and the window guide strip on the outside of the door. Could use some suggestions on the seals. i think if have them all figured out except the lower window seal. what holds the outer seal in and the inner felt seal came with staples. how are the seals installed. any help would be appreciated.
Thanks in advance.
when i took the innerseal out, there were staples in it but not attached to anything. There was not an outer seal in the door.
The outside seal has a T shaped cross section.
I found the page in the assembly manual. im still not sure on the outer lower window seal. Thanks for you help.
There is a track that the t shaped rubber slides in to. It's almost hidden.
