2 members (JeffA, Mike B), 167 guests, and 2 robots.
Topics128,162
Posts1,056,938
Members48,458
I recently bought an OD transmission. I have all the electronic components but need the bracket to hold the kickdown switch to the carburator, and the tab which connects to the linkage - which the kickdown switch pushes against when the throttle is mashed down to cut off the OD unit.
Does anyone know of a vendor or source to get these items? Does anyone have them and can give me an idea on how to make my own.
Thank you
Dennis
ODSS President
ODSS President
I run my '62 3sp+od off of a lighted switch on the dash and don't use any of the kick-down or carb. pariphernalia. The important thing to remember is not to start out in overdrive. I assume you've checked it out before installing. Mine is the non-synchro 1st gear model.
~ Cosmo
1949 Chevy Half Ton
Junior Member
Junior Member
First are you running a I6 or V8? If it's a I6 time to use 2 barrel bracket that's modified or make your own. The best I6 set-up I saw was using a clip off the shifter linkage on the trottle rod to close the switch at the carb.There is a place called C&P Automotive in Kulpsville, PA that might be able to help, the phone number is 800-235-2475.
willy 57
Dennis - check the wreckers and look at kickdowns on any later automatic - shouldn't be hard to adapt or fab yer own based on what ya see
Check out Bowtie Overdrives. They have everything you need. From what Ive been told the adjustment on this cable is critical! Let me knoe how you make out as I plan to put an overdrive in my 46.
No hill for a climber!
