7 members (Uncles51 , baldeagle , 1955 1 Series , 50Chevy3100 , Gray_Ghost , Maybellene , 1 invisible),
107
robot. Key: Admin ,
Global Mod ,
Mod
Topics128,026
Posts1,055,408
Members48,422
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Hello, Can some one help me with the seat riser measurements. Mine was cut off by previous owner. I’d like to put it back to its proper location. Thanks.
1947 pickup-cab seat frame?
3100 - there are several models, some with different seat bases. You need a seat base measurement for a 3104, if it is a pickup. Not the seat base measurements from/for these 3100s: 3105 Panel 3106 Carryall (panel doors) 3107 Canopy Express 3116 Carryall (end-gate) Are you referring to the metal base, or measurents for the seat cushion?
It a pick up 1/2 ton.The metal base see image in post. I want the measurements from the seat riser wall to the end of the floor. Thanks
3" both front and back from seat riser base (vertical part) to edge of floor. I assume you have the part of the riser that extends between the lock pillars at the rear of the seat.
1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car)
Thank you klhansen. That’s the measurement I needed. I’m not sure what part you’re referring to between the lock pillars?
