5 members (32Fordpuchoptop, Otto Skorzeny, Mike B, Bill Hanlon, bluechev), 48 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#1362390 05/28/2020 7:38 AM
Hello, Can some one help me with the seat riser measurements. Mine was cut off by previous owner. I’d like to put it back to its proper location.
Thanks.
47 BOMBER #1362407 05/28/2020 12:04 PM
1947 pickup-cab seat frame?
47 BOMBER #1362496 05/28/2020 9:42 PM
Yes sir ‘47 3100
47 BOMBER #1362519 05/29/2020 1:26 AM
3100 - there are several models, some with different seat bases.
You need a seat base measurement for a 3104, if it is a pickup.
Not the seat base measurements from/for these 3100s:
3105 Panel
3106 Carryall (panel doors)
3107 Canopy Express
3116 Carryall (end-gate)
Are you referring to the metal base, or measurents for the seat cushion?
47 BOMBER #1362528 05/29/2020 2:27 AM
It a pick up 1/2 ton.The metal base see image in post. I want the measurements from the seat riser wall to the end of the floor.
47 BOMBER #1362532 05/29/2020 2:33 AM
3" both front and back from seat riser base (vertical part) to edge of floor. I assume you have the part of the riser that extends between the lock pillars at the rear of the seat.
47 BOMBER #1363460 06/04/2020 6:14 AM
Thank you klhansen. That’s the measurement I needed. I’m not sure what part you’re referring to between the lock pillars?
Moderated by  ndkid275, Phak1
