Hello, Can some one help me with the seat riser measurements. Mine was cut off by previous owner. I’d like to put it back to its proper location. Thanks.
3" both front and back from seat riser base (vertical part) to edge of floor. I assume you have the part of the riser that extends between the lock pillars at the rear of the seat.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
