3 members (TUTS 59, WICruiser, 1 invisible),
125
Mod | | | Forums66 Topics128,090 Posts1,056,382 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | For a Chevrolet 292, what is the main bearing bore diameter in the block (without bearings installed)? And what is the tolerance for being out of round?
The measurement I’m getting using a mic and dial bore gauge is 2.4905” straight up and down (90 degrees away from the cap parting line) But very near the parting line the bore is .0020” larger which seems like a lot. Hoping to avoid a line bore or hone. Thanks. | | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | The Federal Mogul shop specification catalog #115 lists the main bore as 2.4906"-2.4916". Yes, it needs to be round, within those specifications. Are the mating surfaces perfectly clean, and are the bolts torqued while taking the measurements? Side to side dimensions aren't as critical as top to bottom, but a .002" difference is pretty extreme. I usually ignore the dimension at the parting line and rely on a vertical measurement, and one at 45 degrees from vertical both ways. If those are within tolerance, press on! Jerry
| | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | Thanks for looking up those dimensions. The surfaces are cleaned and torqued to 65 ft lbs. I’ll check them again as you described. I’m hoping to not need a line bore or hone. | | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | Be very careful when selecting a machine shop if you do decide to line bore the engine. Gear-drive camshafts can be incredibly critical on timing gear fitting, and the usual procedure of taking out equal amounts in the block and bearing caps can result in gear teeth bottoming out. I usually set up my portable line bore rig to barely scratch the block, and take the majority of the cut out of the bearing caps after shortening them about .010". Yes, I have that equipment. Jerry
