| | | Forums66 Topics128,152 Posts1,057,011 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 330 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 330 | Hello there,
Is there a kit available to convert the truck to an open driveline? I see quite a few kits available for Ford banjo rear ends but nothing for Chevrolet...Another thought I had was to source the parts from a 39 (GMC) 1.5 ton truck to make the conversion... I understand that the transmissions are the same (4 speed) but the rear end is actually different... Still you could at least source out:
1- Rear transmission cover 2- Rear Yoke 3- Driveshaft 4-Center bearing
The issue would be the front differential cover and yoke plus the ring and pinion... BUT if there is at least a kit for a 6 bolt (10 spline?) Chevy differential this may be doable with the other GMC parts? Any help appreciated here...
Philippe Jeanneau
