1 members (baldeagle),
55
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2020 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 114 | when I got my truck last month I saw it had 2 cracked windows, no biggie, today I was checking the pass side wing because it would not stay open. spring was gone, and it looked brand new other than being cracked, then I saw that who ever installed it, bought it with out safety safety glass, no decal any where on the glass, drivers side vent yes. then I checked the drivers door window, same thing, no decal for safety glass. When you order new glass, make sure you ask if its safety of just normal glass.
woof359 Family 1952 3100 5 Window
| | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Look at the bare edge of the glass. If its laminated you can see the two pieces with the plastic in between. Probably was cut from a cut off piece at a glass shop. Stock lights of lami normally have one, sometimes two logos etched in the corner. Custom tempered will usually have a logo, but they are really faint in my experience. Since yours are cracked, they aren't tempered. I'm willing to bet a coffee they are laminated. John | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Woof, Suggest that you edit your signature to include the truck you're referring to if you only have one, or at least mention in your post which of your trucks you're referring to if you have more than one.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2020 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 114 | Thanks for the TIP, makes since
| | | | | Joined: Mar 2020 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 114 | I was looking at the pass side vent window, yep to pieces of glass fused together with no logo any where, could not make out any between layer,...... drivers window, not sure if it 2 layers but no decal for glass Grade for sure. recommendations on places to buy glass ?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here are places that sell that vent glass.They will not be laminated (like the original glass). They will not have date markings (like the original glass). Some of those sellers are well-known and are reliable (some are listed, below): Classic Parts American Classic Parts Ecklers Chevs of the 40s Summit Racing Classic Industustries Bobs Chevy Truck Parts etc | | |
