10 members (jupitor, treegrower, Lightholder's Dad, GMCJammer51, J Lucas, JW51, Tinker5, TUTS 59, wilbur53, 3B),
216
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2020 Posts: 87 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 87 | Hi All, I'm stripping down my cab so I can paint it. I can't figure out how to removed the light switch. It looks like it's welded in place. I'm also having trouble with the glove box latch. I have no key.
Any help would be greatly appreciated.
Mike | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | On the light switch, behind the front of the dash, is a spring loaded button. Push that and your knob with stem will come out. The you can unscrew the bezel and remove the switch.
Sometimes, on old locks, you can put a key the roughly fits, jiggle it around, and unlock it. | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Mike If you have the glove box lock that goes above the door, there will be a clutch head screw holding a sleeve over the lock. Remove that screw (from behind the dash) and the sleeve can be removed. As far as a key, if you're lucky, the key for the glove box will be the same as the door, and you can find the key code stamped on the door lock near the lock shaft after removing that lock. Let me know the code and I may be able to help out with a key cut pattern. What Mark said about finding a key that roughly fits, I was able to do that with the ignition switch that I had no key for. Once I was able to get the cylinder out, there was the code that was slightly different than the one on the key that I used to remove the cylinder.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2020 Posts: 87 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 87 | thank you very much guys. I will look a lot closer and report back. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | I couldn't figure out the light switch removal either. Stumbled onto a website...how simple. I ran into the same puzzler when I was trying to work on the door lock. How do you get the retaining clip on it. I was preparing to remove the door handle when another website bailed me out...a slot in the door under the weather strip! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
