2 members (dunfire, Wayne67vert), 93 guests, and 1 robot.
Topics128,129
Posts1,056,360
Members48,441
#136134 11/21/2006 2:23 PM
I have read throught the site and done a search as well. I under stand there are pullys mounted to the 250 dampner? Does any one make an aftermaket pully like fluid dampner for these engines? Thanks for the time.
Have a fun and productive day.
Slider
Jesus is Love! Never forget the Veteran.
AND God bless Amercia!
#136135 11/21/2006 6:27 PM
Check out www.speedwaymotors.com
I am not sure but I think a small block damper will fit the 250. I am sure someone will be along soon to let you know for sure.
#136136 11/22/2006 1:54 AM
Oh yes? That would be cool. Wonder which one. Thanks for talking the time to answer. Have a good turkey day.
Slider
#136137 11/22/2006 3:45 PM
Go over to the (Inliners.org) site and do a search. There is something about some machining to get the V8 dampner on a L6. Its not much, something about cutting the snout a little. Joe
#136138 11/22/2006 5:46 PM
Thank you fella`s!
Slider
#136139 11/27/2006 10:38 PM
The small block Chevy dampner will work on the 250 but you will have to machine about a 1/4 inch off the crank side of the "snout" that fits over the crank. I have run a Fischer, an ATI Super Damper, and a Fluid Damper all with good sucess on a 292. They share the same timing cover so I don't see why it shouldn't work. If you are going to spin the engine very fast it is a must. The one 292 I shift at 6800rpm and have never had a crank problem.
