| | | Forums66 Topics128,134 Posts1,056,416 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 | I have read throught the site and done a search as well. I under stand there are pullys mounted to the 250 dampner? Does any one make an aftermaket pully like fluid dampner for these engines? Thanks for the time. Have a fun and productive day. Slider
Jesus is Love! Never forget the Veteran. AND God bless Amercia!
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Check out www.speedwaymotors.com I am not sure but I think a small block damper will fit the 250. I am sure someone will be along soon to let you know for sure. | | | | | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 | Oh yes? That would be cool. Wonder which one. Thanks for talking the time to answer. Have a good turkey day. Slider
| | | | | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | Go over to the (Inliners.org) site and do a search. There is something about some machining to get the V8 dampner on a L6. Its not much, something about cutting the snout a little. Joe | | | | | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 |
| | | | | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | The small block Chevy dampner will work on the 250 but you will have to machine about a 1/4 inch off the crank side of the "snout" that fits over the crank. I have run a Fischer, an ATI Super Damper, and a Fluid Damper all with good sucess on a 292. They share the same timing cover so I don't see why it shouldn't work. If you are going to spin the engine very fast it is a must. The one 292 I shift at 6800rpm and have never had a crank problem. | | |
