| | | Forums66 Topics128,052 Posts1,055,738 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2020 Posts: 87 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 87 | Can someone please tell me the correct location for the side-view mirror for a 1950 Chevy PU?. I have three sets of holes, top of cowel, top of door above the glass, side of door just below the glass. I am doing bodywork and want to weld the incorrect holes closed.
thanks for any help. Mike | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mike,
for optional/accessory mirror - top of cowl
Look under the dash, under the cowl-attachment location.
If the holes are in the correct location, you should see the holes inside a brace/bracket. | | | | | Joined: Mar 2020 Posts: 87 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 87 | Tim,
thank you very much. I thought so. Time to weld those others shut. | | |
