4 members (dt235sd, KEVINSKI, Otto Skorzeny, Charles in CA), 90 guests, and 0 robots.
Topics128,051
Posts1,055,732
#1361106 05/20/2020 2:28 PM
hope this is a good spot. I found that the tank in my 59 is leaking. its the orig tank so it has done its job. I wonder about a new tank from one of the truck parts places or a custom aluminum tank. the price for custom will be a bit higher but may last longer. Anyone had experiance with either option?
59chevy36 #1361113 05/20/2020 2:51 PM
Crusing in the Passing Lane
Almost everyone that has replaced an old tank with a new one, has never complained on here.
Ed
59chevy36 #1361114 05/20/2020 3:05 PM
I used Gas Tank Renu for three of my tanks: two 1954 3104 pickups and one 1954 3106 Suburban.
Their pricing and service was excellent.
I removed and installed the tanks.
I have had no problems for about 20 years.
59chevy36 #1361125 05/20/2020 3:39 PM
If you are interested in reusing the old tank, check with a local radiator shop. Some of them will also do gas tanks. I had my 46 tank done by a local shop back in NJ. They asked if it was going to be a show truck, as there process was a little different if the truck is being graded. But for a daily driver, they cut an access hole in the tank, cleaned it, re welded the tank, and sealed it. I think it was $100 10 years ago.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
59chevy36 #1361133 05/20/2020 4:15 PM
Mine were done in local radiator shops.
59chevy36 #1361290 05/21/2020 3:18 PM
I didn't think of a restore. Will try some local shops. The tank looks ok except for a area on the bottom cheaper than new. Thanks
