0 members (),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 17 New Guy | | New Guy Joined: Jan 2014 Posts: 17 | My big bolt 4 speed transmission frequently grinds when going in 2,3 or 4th gear. Seems less so when I have a load on the dump.
Ideas for problem, can you get parts if you want to rebuild. Truck only has 13,000 miles....former fire truck.
thanks,
Pierre | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I think the 1949 GM truck transmission was an SM420. If that is correct, parts are available. That transmission should last for much more than 13,000 miles. Is there water in it (empty into a catch-pan by removing drain plug in the bottom). Maybe someone else will post helpful diagnostic advice? | | | | | Joined: May 2017 Posts: 330 'Bolter | | 'Bolter Joined: May 2017 Posts: 330 | In addition to the above, it could be out of oil or there could be a clutch problem. Is the clutch releasing all the way? (Does it shift from neutral into 1st and reverse easily without grinding, engine running, truck stationary?)
Mac :{)
1962 K10 short step side, much modified for rally 1969 T50 fire truck, almost nos, needs a few things
| | | | | Joined: Jan 2014 Posts: 17 New Guy | | New Guy Joined: Jan 2014 Posts: 17 | Thanks....transmission oil was changed with no difference. Clutch seems fine. It does go into first or reverse easily when stationary. | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | What type trans oil did you use? The modern multi grade and synthetics oils can be to thin/slippery and don't allow the gears to slow down between shifts. Mike B  | | | | | Joined: Jan 2014 Posts: 17 New Guy | | New Guy Joined: Jan 2014 Posts: 17 | Mike,
Wow you have some great vehicles. I am not sure i guess. I had it serviced by mechanic when I first bought it. What do you recommend. Certainly worth it to change again just to make sure. Doesn't seem right that at 13,000 miles there would be a problem. I understand these are great transmissions. | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | Thanks for the compliment. You need to use SAE 90w Mineral Oil. Mike B  | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | pierrem sounds like clutch is draggy my 51 sm420 has 113000 not easy miles on it shifts fine...when you pull up on a little slope and clutch it will it offer to roll back ?? if not look at clutch. | | |
