3 members (ronsway, ndkid275, klhansen), 89 guests, and 3 robots.
Topics128,090
Posts1,056,374
Members48,442
My big bolt 4 speed transmission frequently grinds when going in 2,3 or 4th gear. Seems less so when I have a load on the dump.
Ideas for problem, can you get parts if you want to rebuild. Truck only has 13,000 miles....former fire truck.
thanks,
Pierre
I think the 1949 GM truck transmission was an SM420.
If that is correct, parts are available.
That transmission should last for much more than 13,000 miles.
Is there water in it (empty into a catch-pan by removing drain plug in the bottom).
Maybe someone else will post helpful diagnostic advice?
In addition to the above, it could be out of oil or there could be a clutch problem. Is the clutch releasing all the way? (Does it shift from neutral into 1st and reverse easily without grinding, engine running, truck stationary?)
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Thanks....transmission oil was changed with no difference. Clutch seems fine. It does go into first or reverse easily when stationary.
What type trans oil did you use? The modern multi grade and synthetics oils can be to thin/slippery and don't allow the gears to slow down between shifts.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike,
Wow you have some great vehicles. I am not sure i guess. I had it serviced by mechanic when I first bought it. What do you recommend. Certainly worth it to change again just to make sure. Doesn't seem right that at 13,000 miles there would be a problem. I understand these are great transmissions.
Thanks for the compliment.
You need to use SAE 90w Mineral Oil.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
pierrem sounds like clutch is draggy my 51 sm420 has 113000 not easy miles on it shifts fine...when you pull up on a little slope and clutch it will it offer to roll back ?? if not look at clutch.
