10 members (Gray_Ghost, Shade Baby, 68ironhead, Gdads51, Pre '68 Dave, Otto Skorzeny, 1955 1 Series, joe apple, dt235sd, PAUL Berardi), 137 guests, and 1 robot.
Topics128,104
Posts1,056,197
Members48,436
#136091 12/22/2006 1:44 PM
I have a new 350 crate in my panel. I was given a vintage set of valve cover gaskets without the oil filler or PCV valve. Can I run these or should I? I am running a Edlebrock carb so I if I do run them I'm assuming I just block off the line?
Mac
#136092 12/22/2006 3:11 PM
Your motor has to breath one way or another.How would you add oil? You can use the PCV system(closed system),open breathers through the valve covers or an early style intake manifold if your heads will accept it.Look at the two intake bolts on each side of the carb.If they are vertical and not angled like the others,you can NOT use an early style manifold without machine work.I reworked one and it was not worth the trouble.I would look for some nice open breather valve covers.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#136093 12/22/2006 4:33 PM
yes, use the pvc. Motor needs to breath or you will blow seals and gaskets. Ive heard that you can go through the manifold if u dont want to drill the covers.
#136094 12/22/2006 8:25 PM
look at the back side of the valve covers and see if there is a "knock out" for the oil breather/oil filler.
Another quality post.
Real Trucks Rattle
#136095 12/22/2006 9:12 PM
thanks!
#136096 12/25/2006 6:29 AM
Also understand that you have to let clean air into the block and the dirty air gets pulled out by the PCV line. This is how the blowby and other gasses get pulled out of the block. If you just vent the block without a system to move the bad air out you will soon have acidic oil.
lg
no neat sig line
#136097 12/25/2006 2:25 PM
Yes you do need to run the PCv valve. I didn't put one in and just blocked the hole in the valve covers off and the cap has no breather while I finished building. Well I messed up bad. Didn't pay attention and built up pressure in the motor and blew out the oil pan gasket. My own fault. And all I was doing was going from the grage out and back several times and running the motor just to keep it lubed up properly.
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
