1 members (Dusty53),
174
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | I have a new 350 crate in my panel. I was given a vintage set of valve cover gaskets without the oil filler or PCV valve. Can I run these or should I? I am running a Edlebrock carb so I if I do run them I'm assuming I just block off the line?
Mac | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Your motor has to breath one way or another.How would you add oil? You can use the PCV system(closed system),open breathers through the valve covers or an early style intake manifold if your heads will accept it.Look at the two intake bolts on each side of the carb.If they are vertical and not angled like the others,you can NOT use an early style manifold without machine work.I reworked one and it was not worth the trouble.I would look for some nice open breather valve covers.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | yes, use the pvc. Motor needs to breath or you will blow seals and gaskets. Ive heard that you can go through the manifold if u dont want to drill the covers. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | look at the back side of the valve covers and see if there is a "knock out" for the oil breather/oil filler.
| | | | | Joined: Jul 2005 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 153 | | | | | | Joined: Dec 2006 Posts: 8 New Guy | | New Guy Joined: Dec 2006 Posts: 8 | Also understand that you have to let clean air into the block and the dirty air gets pulled out by the PCV line. This is how the blowby and other gasses get pulled out of the block. If you just vent the block without a system to move the bad air out you will soon have acidic oil. lg no neat sig line | | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | Yes you do need to run the PCv valve. I didn't put one in and just blocked the hole in the valve covers off and the cap has no breather while I finished building. Well I messed up bad. Didn't pay attention and built up pressure in the motor and blew out the oil pan gasket. My own fault. And all I was doing was going from the grage out and back several times and running the motor just to keep it lubed up properly.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
