4 members (elhippie64, baldeagle, Phak1, 1 invisible), 51 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,420
#136021 11/12/2006 5:01 PM
I have a TCI IFS in my '57. The new cross member is welded in and the frame was boxed in the area of the new cross member.
Can I safely remove the old cross-member/motor mount?
(New engine will be a 400hp+ small block.)
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
#136022 11/15/2006 1:26 AM
Those are pretty stiff frames. I don't see why you couldn't remove the old crossmember if you have the new one welded in place. But like you said, you need to support the motor differently it sounds like.
...Or you could leave the old crossmember in there to add stiffness to the frame.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
#136023 11/15/2006 2:14 PM
Thanks. As a followup, I called Classic Performance in California and they gave the green light to hack it out. I also found a book ("How to Build Tri-five Chevy Trucks" - HPBooks) that removed the cross member after installing the new TCI cross member because it interfered with the rack and pinion unit. Even so, I think I'm going to weld in a 2x4 box between the front frame rails just because.
More pix in Picasa
#136024 11/17/2006 2:31 PM
Added weight=slower truck, just depends where your plans are. not much wrong with frame flex if you are still strong enuf. grin
