3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1359812 05/11/2020 7:04 PM
Hello bolsters
In France today we come back to the work 😷
What is the best carburetor for my 235 ci ,54 ,3100 1/2T to replace the old one (pics)
Amitiés
Alain
is it not rebuildable?
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
I’ve already used the carburetor rebuild kit from classic parts but not perfect
Alain
I just replaced my Rochester B with a Carter YF. Runs nicely. Carters are frequently described as superior to the Rochester carb.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Ok merci Spotbiltxo
I used a model N228 from Mikes Carburetor Parts to replace mine and it works great.
Only works with clamp on air cleaners though it doesn’t have the long bolt for the original one.
Carburetion specialist
Lots of folks like the Carter type YF better than the Rochester B.
Carter suggested the 2100s with manual choke; or the 2101s with hot air automatic choke for the 1954 235 CID engine.
Jon.
The Carburetor Shop
One other comment, do you everything you can to make sure there isn’t something else going on besides a bad carburetor. There are many threads here that suggest making sure everything else is correct before blaming the carb, such as timing, coil, points, and the number one culprit these days...... old stale gasoline!! Two or three years ago I learned that lesson. After blaming the carburetor for all my problems I saw them all go away after filling the tank with fresh gas. It ran like a champ after that. We have 10-15% ethanol in our fuel here in the U.S. Don’t know if you also have ethanol in your fuel in France, but if you do double check to make sure it’s not over 30 days old. If it is then it will make your truck run poorly. Change it out for fresh gas!
Chuck
1941 Chevy coupe
