0 members (), 74 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1359729 05/11/2020 3:54 AM
I need to replace the head gasket in my super charged 270 GMC. any suggestions of what type, brand name to get I have a water pressure problem I can't figure out. after driving it 10mi. or so it starts to push water out of the cap, replaced the cap and that didn't fix the problem.
Jay D.
jay d #1359748 05/11/2020 12:11 PM
Any pics of that supercharged setup?
jay d #1359765 05/11/2020 2:00 PM
H Online: Content
On the blower-equipped tractor pullers we built, we used solid copper head gaskets 1/8" thick and stainless steel O rings around the cylinders to seal the compression.
jay d #1359820 05/11/2020 7:21 PM
How much boost do you have? Head gaskets can handle 10-12 #'s and above that one needs to "O" ring the cylinders as Jerry suggested. Before you start ripping things apart do a search for an "engine combustion gas detector". They run from $25-$50 and will show if a head gasket (or head) is leaking. Just plug into radiator cap hole and if detector fluid changes color something is leaking. You can even get fancy and test with each spark plug wire off till you find the one where the color doesn't change---that's the trouble spot.
Evan
jay d #1359835 05/11/2020 8:16 PM
H Online: Content
Evan, NAPA sells that setup under the name "Block Test Kit". BTW, the similar kit sold by O'reilly Auto Parts has similar-looking blue fluid, but it's not nearly as predictable as the NAPA fluid for some reason. It turns yellow in the presence of a small leak, or green if there's a bad one.
its a 270 with a .060 over bore and a big valve 302 head it runs about 7.5 static comp. with a boost of 10 - 12 psi on forged Venolia pistons.[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/18298/filename/53 Chevy 01 - Copy.jpg[/img][img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/18300/filename/Copy of ebay 1 491.jpg[/img][img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/18301/filename/ebay 1 487.jpg[/img]
Jay D.
jay d #1360028 05/12/2020 11:17 PM
Crusing in the Passing Lane
What intake manifold is that?
Ed
jay d #1360055 05/13/2020 2:05 AM
Funny looking truck. No problem by me. That is definitely a truck engine.
EdPruss #1360068 05/13/2020 3:15 AM
Ed
ED, I got the manifold from Ronny Cox probably 20 yeas ago. he was a inliners member and had a big truck dragger. I got the manifold, head, side cover, rocker cover and some other trinkets from the drag truck. also got a lot of help from [censored] Larrow that had Stovebolt Engine back then. its a real strong running engine.
Jay D.
jay d #1360113 05/13/2020 2:30 PM
H Online: Content
Are you running studs instead of head bolts on that rig? I'd definitely recommend getting a gasket made from .090" thick solid copper for it. Machine a 1/16" wide groove .030" deep in the block around all the cylinders, and form a ring of .060" stainless steel safety wire to fit the groove, with a very snug butt joint where the ends meet. As the studs are torqued, the wire will imbed itself into the soft copper and seal the cylinder pressure much better than any regular head gasket can. Use Permatex Super 300 brush-on sealer on both sides of the copper to seal the coolant.
yep that would be the way to go, and I may very well do that to the 302 block I have. everything else will change over from the 270 except pistons.
Jay D.
