3 members (ronsway, NJC, dt235sd),
152
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | Apparently one of my axle seals is leaking. When I jacked up one side of the truck oil ran out of the other and got all over my drums and brakes shoes. I forgot to clean it up before I moved the truck. Are the brake shoes completely ruined? They are brand new. Dang Thanks. | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Yep, they're trashed. No matter how you try to clean them, once the brake gets a little warm, more oil will seep out of the linings and contaminate things again. I've soaked linings in various solvents, heated them, sanded them, etc. and nothing has ever worked. Bite the bullet and replace them. Jerry
| | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | I was afraid that would be the answer. Dang old age. Thanks I appreciate you. | | |
