9 members (Wayne67vert, DaveV, Phak1, Eisenholtz, Ponchogl, Bill Hanlon, 55shaker, Rusty Rod, TUTS 59),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | I would like to move my transmission/transfer case forward about 1/2 inch to make more room for the HEI distributor cap. I know it would shorten the front drive shaft's travel and extend the rear. I'm not particularly worried about the rear, as there is a lot more wiggle room in the back.
1967 Chevy Suburban K20. Rockwell T221 Transfer case/SM420. Dana 44 front diff, Eaton rear diff. SBC 327 V8.
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | It would probably be a lot simpler and less expensive to modify the firewall. There won't be any changes in driveline geometry and clutch linkage that way. I believe you're about to open up a huge can of worms by tinkering with the position of driveline components. Jerry
| | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | Thanks HRL, I did "massage" the firewall a little bit, but I don't want to get too rambunctious with the sledge.
| | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | I'm with Hotrod, don't mess with success.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | How about fabricating a semi-circular piece of sheet metal and welding or riveting it into an appropriate-sized cutout behind the distributor? It's a little more work than the hammer method, but a lot less redneck! Jerry
