4 members (JeepJoker, Chip O, Bill Hanlon, Guitplayer), 80 guests, and 2 robots.
Topics128,035
Posts1,055,447
Members48,422
#1359249 05/08/2020 5:06 PM
I read the manual, it gave specs that the door could stick out 1/8 or so and still be Ok, I have a solid straight cab but the pass door is hard to shut, worse with windows up, door has a new latch, I have moved the striker plate all the way out with no change, if I take the striker off, the door seems to close all the way,.... so I drilled out the adjustment holes out so I could slide the striker further outward,, better now but not great, Ideas from other that have been here
woof359 Family 1952 3100 5 Window
woof359 #1359285 05/08/2020 11:05 PM
Just today I installed door seals and adjusted the striker plate on the drivers side to get the door to close better. What year truck are you working on and pics would help.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
woof359 #1359293 05/09/2020 12:03 AM
Yes, would be nice to know what year/model are we referring to.
Craig
