| | | Forums66 Topics128,156 Posts1,057,019 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 76 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 76 | Is a 10" clutch plate ok for use on a 265 V8 small block with a 4 speed muncie.Truck only gets used at weekends for cruising about.The truck had a 10" on when I got it but was wondering if it's up to the job.The flywheel will only take upto 10.5" anyway. | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | When I did the 235 to 350 conversion on my 56 the only V-8 flywheel I could find at the time used a 10" clutch. It worked fine for several years. I subsequently changed to an 11" later when some other changes were made. I really didn't see any difference. Fred
