| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 87 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 87 | I have a 69, C60, 24k gvw, 427, 5 speed/2 speed rear. It's not the prettiest truck yet but it's in great shape. I've been doing quite a bit of work to it to get it ready for the road. At most once it is all said and done I'll probably haul a max of 10-12k pounds or so. I would like to improve the ride quality unloaded but be able to maintain the capacity to haul what I need to. Currently it rides like it should but I would like to make it better. Has anyone pulled leafs from the spring packs at all 4 corners and added air bags to their truck? This seems like the simple solution and air wouldn't be a problem since I have air brakes with an engine mounted compressor. I'm open to other options too and would like to hear some ideas if you have them. I'm a pretty handy fabricator with access to more tools and equipment than most.
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | JMO. If i was hauling 10 to 12k of whatever, i wouldnt be that concerned about the empty ride as much as the loaded. Unless the load is far and few between. But if its a regular thing, im not sure id change anything yet, till ive had some time with it on the road, particularly loaded.
| | | | | Joined: Feb 2019 Posts: 87 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 87 | It will be loaded maybe half the time. I only plan to put a couple thousand miles on it per year. The other half of the time I will be venturing the Michigan road ways that are notoriously horrible in something that rides pretty good anyways. For that thousand miles or so that I will be driving it empty per year to me makes it worth it in itself, I'd like to enjoy cruising it. Currently I can run over a dime and tell you if it's heads or tails empty. | | |
