| | | Forums66 Topics128,077 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 4 New Guy | | New Guy Joined: Aug 2012 Posts: 4 | Hello, I was curious if there are any 4400s out there with custom pickup beds? Just an idea im tossing around for my stake body.... Id love to see some pics or ideas! | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | The 3800 and 4100 have very similar frames, same wheel base, frame cross section, etc. You could take a 1-ton pickup bed and put it on a 4100 but I believe the 4400 used a heavier frame with a longer wheelbase. But, that frame could be ordered as a heavy-duty frame on a 4100, RPO xxxx. There may be a short wheelbase 4400 out there somewhere. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | There may be a short wheelbase 4400 out there somewhere. The second "number" in the series indicated the chassis wheel base, so all factory 4400's are the same length... Mike B  | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | That heavy duty option on the 4100 was basically just using a 6100 frame.
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
