9 members (48jim1ton , Gdads51 , Forty9 , Hotrod Lincoln , gswbbc , frogfarmer , Wayne67vert , sron48 , dt235sd ),
75
0
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,043
Posts1,055,540
Members48,425
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Hello I have a 1947 3100 half ton with a 1955.2nd 235 engine, the 1947 bell housing, and has the original rear end. Later I plan to swap it out for 3.55 to 1 ring and pinion. A guy is selling this transmission for $350 and I need help with ID and if it would work for my truck? Con 6 9L292 GM 591953
Crusing in the Passing Lane
'47 could be non'syncro 4 speed, a good trans. But 420(synchro) would be more useful. Price sounds high. Ed
That's an SM-420...
L292 is the date code
L = December
29 = Day
2 = Year (1952 or 62 ???), that casting number was used from 1948-63.
Mike B
So it is synchronized? Would it bolt up to the ‘47 bell housing? If it’ll work for my truck I’ll try to talk him down on the price. I been looking for a good transmission but all I’m finding is junk lol.
Novak in SLC make kits for 420's, although some synchro are no longer available. Ed
Those are good transmisisons, but I wouldn't pay $350 for one unless it was rebuilt and comes with the paper work and a warranty. Good used ones aren't to hard to come by for $50-$100 where I come from
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
Being for a torque tube rear will add a little (they are a little harder to find), but not three to four times as much!
Mike B
