| | | Forums66 Topics128,180 Posts1,057,145 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 9 New Guy | | New Guy Joined: Feb 2013 Posts: 9 | Looking for the correct Vacumm Advance Line size for a rochester model B carb. Does 1/16th sound right?
Thanks, | | | | | Joined: Mar 2014 Posts: 4,509 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,509 | If you mean the metal tubing, I think the od was about 1/8". It depends on the fittings on yours, also. Some were flared and some used the crimp ferrule thing. Feels nice out there today, doesn't it?
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2013 Posts: 9 New Guy | | New Guy Joined: Feb 2013 Posts: 9 | 1/8th. Thanks. this one had some compression fittings. Yes, finally getting warm here.
Thanks, | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | The original equipment line was 3/16" OD. A 1/8" ine will work, but you'll need to do some adapting. The vacuum advance has a 3/16" inverted flare female fitting. Jerry
