7 members (Bill Hanlon, Guitplayer, LAROKE, Cosmo, JoergK., Wayne67vert, 4tttt8), 108 guests, and 6 robots.
Topics128,180
Posts1,057,167
Members48,465
Looking for the correct Vacumm Advance Line size for a rochester model B carb. Does 1/16th sound right?
[Linked Image from i1297.photobucket.com]
Moderator, Electrical Bay
If you mean the metal tubing, I think the od was about 1/8". It depends on the fittings on yours, also. Some were flared and some used the crimp ferrule thing. Feels nice out there today, doesn't it?
~ Jon
1/8th. Thanks. this one had some compression fittings. Yes, finally getting warm here.
The original equipment line was 3/16" OD. A 1/8" ine will work, but you'll need to do some adapting. The vacuum advance has a 3/16" inverted flare female fitting.
