3 members (Samantha, UtahYork, Stovebolt48), 107 guests, and 3 robots.
Topics128,049
Posts1,055,637
#1358428 05/03/2020 8:39 PM
'56 GMC F350. I really don't know much about 2 speed rears. There's a switch in the dash with pipes coming off the back. 2 go straight thru the firewall and to the axle but the 3rd, which is smaller in diameter, heads under the dash and has a cap on it. Should that one be connected to a vacuum somewhere? maybe manifold?
hotshoe99 #1358465 05/04/2020 1:04 AM
That one is supposed to power a vacuum-shifted gearbox somewhere in the speedometer cable housing or maybe on the back of the speedometer head to change the ratio so the speedo is accurate in both rear end ratios.
hotshoe99 #1358481 05/04/2020 3:33 AM
There should also be a vacuum line to the vacuum source and there could also be a port for fresh air coming off of the air cleaner if I remember correctly.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1358593 05/04/2020 10:11 PM
Thanks, I'll look at what I have and see if I can figure it out
