6 members (Bill Hanlon, Gdads51, Otto Skorzeny, UtahYork, dt235sd, Ponchogl), 115 guests, and 5 robots.
Topics128,089
Posts1,056,130
Members48,435
Hello, I am replacing my inner cowel. I'm not sure how to remove the weather strip retaining strip. It's the piece of metal that wraps around the door frame on the inside of the truck which holds the weatherstripping. It looks like i'ts welded onto the cowel. Do I need to find spot welds and drill them out?
any help would be appreciated.
Mike
It is spot welded on, but it's pretty thin metal, so you can probably just pry it loose with a screwdriver or seambuster tool. I just removed some of mine by cutting with a body saw "just" thru the weatherstrip retainer, then pried it off. You could drill out the spot welds, but that seems like more trouble than it's worth to me.
Thank you Kevin
Mike, just for informational purposes the Driveline Forum is not the proper place to ask a Paint and Body question. Before posting look through the various forums and post in the most appropriate forum. Kevin graciously answered your question because he’s a nice guy. Drive on.🛠
You may want to look at the cost of the reproduction windlace retainers before you hack your old ones up. Ouch!
Pretty hard to save the retainers. Even drilling out the spot welds is going to leave them in pretty bad shape. You either buy the repop chunks or fab your own if you have access to a sheet metal brake.
