3 members (Peggy M, Joe H, Wayne67vert), 52 guests, and 2 robots.
Topics128,026
Posts1,055,402
Members48,422
#1358019 05/01/2020 1:41 AM
Custom Title
Custom Title
I finally got the Ebrake all put together in my 49 3600. The brake itself holds fine, but the pedal doesn't stay down unless I'm pushing in on the release handle. As soon as I let go the pedal pops right to the top. How is this thing supposed to work? I'm starting to think I'm missing a part somewhere or something... Help!
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
Do you have the spring in place that goes around the pedal link and underneath the release lever to keep the release handle down? If you have a shop manual, check page 5-6.
Custom Title
Custom Title
Yes, that spring is in place
49 Chevy 3600
65 Chevy K10
Possibly the hole in the release bar is worn. A sharp edged hole would be more effective at grabbing the pedal link.
Custom Title
Custom Title
Hmmm... I'll have to take a closer look at it. I wonder if just sharpening up the edges a bit will do the trick
49 Chevy 3600
65 Chevy K10
On occasion I had to put a little more angle on the lock bar where the round shaft goes through so it gets a better bite.
My Blog
southtowns 27--Make sure the lock bar has no paint or rust--I had to sand mine--then it worked fine--Bill
Make sure there is no floor mat, or jute, or carpet wadded up under the lock bar, preventing the spring from doing its job.
