3 members (Danielbolt, bluechev, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2020 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2020 Posts: 55 | Hi there
Just waiting on some parts to get this truck started, or attempt to start, after sitting for more than 20 years. I spun the engine over with the starter to do a compression test, and the results are as follows:
#1 - 140 psi #2 - 65 psi #3 - 70 psi #4 - 145 psi #5 - 155 psi #6 - 150 psi
I was happy with all but #2 & #3, i sprayed penetrating oil in and let it soak for a day, then added some ATF and soaked for two more days with periodic cranking by hand. We did the test on #2 & #3 last night and the compression came up to 115 psi on both. This is better but still along way from the rest of the cylinders. My assumption is that there were a couple of stuck rings after sitting so long, and my questions are:
1- have any of you had similar experiences with sitting engines? 2- Is my assumption of stuck rings correct, or at least possible? 3- Do you think that these could free up once the engine is running and warms up? 4- Is there any precautionary advice to offer before i fire this with the current compression test results.
Thanks in advance Jeremy
1955 3600 father and son project
| | | | | Joined: Aug 2017 Posts: 671 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 671 | Did you confirm all valves are free moving not Stuck? Focus on the valves for #2 & 3 cylinder. If stuck I took a rubber mallet & wood block and knocked on them. On my old 216, which did the trick for me. Hopefully others will chime in soon. Todd
1950 Chevy 3100
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Since the readings came up 40 lbs or better your reckoning of stuck rings may be right. But, be sure your valves are not sticking or bent push rods from cranking the engine. Good luck.ðŸ›
| | | | | Joined: Apr 2020 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2020 Posts: 55 | Thanks for the response
Before i did anything i pulled the valve cover and cranked by hand to ensure the valves moved freely, it turned over quite easily. i will check bent push rods, but wouldn't that shorten the opening of the valve, rather than affect the closing? Or am i checking bent rods to see if they may have been caused by a stuck valve?
Thanks Jeremy
| | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | Valves that don't open far enough (especially intakes) will affect compression by restricting the intake path. Starting farther below atmospheric at the bottom of the compression stroke effectively reduces the compression.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2020 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2020 Posts: 55 | Ahhhh thank you, i never thought of that but totally makes sense!!
| | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | One quick way to find a bent pushrod involves watching the engine at idle with the valve cover off. A straight pushrod will spin at random. A bent one will stay in the same position with little or no rotary motion. It's almost impossible to eyeball a pushrod and see if it's bent, unless it's rainbow-shaped from a badly stuck valve. Another checking technique would be to remove all the pushrods and roll them over a completely flat surface like a sheet of plate glass.
My favorite method of freeing up sticky piston rings is to run the engine at a fast idle for 15-20 minutes with a fresh fill of cheap 30 weight oil and a couple of quarts of Diesel fuel added to severely over fill the crankcase. The crankshaft counterweights splashing into the oil/solvent mix will scrub the crankcase, pistons, and rings like they were in a washing machine. DO NOT drive the vehicle or put any load on the engine while the Diesel fuel is in there. Drain the stuff out while the engine is still hot, change the filter, and refill the engine with oil. I like 15W-40, but opinions on oil are like "noses"- - - -everybody's got one, and some are pretty smelly! Jerry
| | | | | Joined: Apr 2020 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2020 Posts: 55 | Thanks for the info
I like the diesel suggestion, but do you think I risk any internal damage as this unit does not have the optional oil filter?
| | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | I've used many gallons of Diesel fuel that way, and the only engines that gave trouble were worn out already- - - - -the solvent bath just dislodged some of the gunk that was keeping worn out piston rings pushed out against the cylinder walls. You'll either improve things, or confirm that the engine REALLY needs a rebuild!
If you do have to rebuild it, at least you won't have to scrape as much crud out- - - - -splashing the Diesel around inside does a better job of dislodging sludge than hours spent with a brush and solvent after removing the oil pan. Jerry
| | | | | Joined: Apr 2020 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2020 Posts: 55 | Thanks Jerry
I will give it a try, 5 litres (quarts) of oil and 2 of diesel. Hoping the carb kit shows up on Friday and i will get it fired this weekend, i will post how it went.
Jeremy
