8 members (Shaffer's1950, TexasJim50, Opelika Tom, Oswald, Peggy M, dt235sd, Wayne67vert, Charles in CA),
68
Mod | | | Forums66 Topics128,077 Posts1,056,281 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Are 1939 rear fenders (half ton) the same as the 1941-1946(7) rear fenders? I need my short term memory refreshed. Same dimensions - width etc? thanks. Tom | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Visually the same , except the '39 are wider . I think the deck width is 45" for '39 and 48" for later , so the early guards are 1 1/2" wider . | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Got it. Good to know. Thanks | | |
