0 members (),
70
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 223 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 223 | We need to buy a good carburetor for a 228 gmc 1951. it doesn't need to be an original, just want something that's dependable and runs good. it has a Rochester now but we can't get it to stop flooding. any good suggestions would be apricated. Jay D.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Is the float drowned? Is the float level correct?
Ed
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | "The ABC's of carburetion- - - -Always Buy Carter"! Give Jon (Carb King) a call and ask him which Carter YF was designed for that engine- - - -then buy one. Problem solved! Jerry
| | | | | Joined: Nov 2002 Posts: 2,772 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,772 | Thanks Jerry, but Carter did not specify a YF specifically for the GMC 228. GMC 228 original Zenith carburetors are fairly easy to find, and nowhere near as expensive as the GMC 270 carburetors. I would suggest an original Zenith for the 228. But before doing anything to the carburetor; check the fuel pressure. Very easy to blame the Rochester B for anything that needs blaming (and generally one would be correct  ); but even a Rochester B has no chance if someone put on an electric fuel pump without a bypass style regulator, or one of the new off-shore made mechanical fuel pumps. We tested a brand new 2019 pump from a very well known American company (this one made in China) that was rated 5 1/2 psi and put out 13. Testing to determine the faulty component is important. Jon.
Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2013 Posts: 223 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 223 | he has check everything installed new kit set float level several times. I even had him set the float down more than spec. so the float wouldn't have to come up so far to shut it off, no good. check as well as he can the movement of the float and that seems to be ok. the one thing he hasn't done is to check fuel pump pres. its a mechanical type and been on the truck for years and always performed good. can they all of a sudden produce to much pressure? I've always had them go bad with not enough pres. not to much. mind everyone this is not just a weeping gasket its a good steady stream pouring out the bottom of the underside of the carb float bowel.
Jon, right now he just wants to make it run so he can drive it. do you have a carb that will work for him? and how much? thanks Jay D. | | | | | Joined: Nov 2002 Posts: 2,772 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,772 | Have him test the fuel pressure, before ordering a carburetor.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | If you can’t fix the one you have then:
Second vote for the original Zenith carburetor. There’s a good reason GMC chose the Zenith over the others ...........
| | | | | Joined: Mar 2013 Posts: 223 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 223 | Have him test the fuel pressure, before ordering a carburetor.
Jon. hopefully he has time to check the fuel pressure tonight. Jon, would you have a zenith we could maybe buy if we need one? Jay D. | | | | | Joined: Nov 2002 Posts: 2,772 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,772 | Jay - with all due respect, these forums are for technical questions, not sales.
The forum moderators are pretty lenient, but maybe that is because we try not to need their moderation.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2013 Posts: 223 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 223 | my boy finally checked fuel pres. its a steady 5psi. we are still with the idea that the floats are binding up on something. he going to try and see if he can get them right. there should be a measurement for float drop we can't seam to find that does anyone know what it should be? I wish I had an old carb top that we could cut away the part over the floats then one could look at the floats in the float bowl and see what they were doing. Jay D. | | |
