Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
Don't worry about the cracked insulation- - - -it's not all that uncommon. Be sure to carefully check the clearance of the bushings on both end frames- - - -worn ones will allow the armature to drag on the field coil pole shoes and slow the speed down, and also create metallic dust inside the housing. Inspect the commutator bars for any evidence of burning on the edges- - - -that indicates a shorted winding that's making contact with the armature laminations. The bars I can see don't show any evidence of that problem.
New brushes and bushings, plus a new pedal switch should put it back in good shape for a long time to come. The best thing you can do to assure long starter life is keep the engine well-tuned so the starter doesn't have to run for very long each time it's used. Jerry
