Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, Ponchogl, truckernix), 111 guests, and 2 robots.
Topics128,277
Posts1,058,453
Members48,490
#1357453 04/27/2020 5:31 PM
Hey guys,
Here's some pictures from inside my 12v stomp starter.
Should I be worried about the cracked resin? Is there some product I should paint it with to fill the cracks?
It worked before disassembly and I'm planning to re-use it, maybe just give it a new stomp switch and brushes.
There was a bunch of copper debris between many of the commutator bars and I'm surprised it worked so well?!
I cleaned it out with a hack saw blade.
[img]https://imgur.com/jiXNW4q[/img]
[img]https://imgur.com/jZS6SaG[/img]
[img]https://imgur.com/INGi6NH[/img]
[img]https://imgur.com/tx38C2t[/img]
[img]https://imgur.com/WwL7v5W[/img]
[img]https://imgur.com/bVzYOwo[/img]
'59 Chevy Suburban, NAPCO
Don't worry about the cracked insulation- - - -it's not all that uncommon. Be sure to carefully check the clearance of the bushings on both end frames- - - -worn ones will allow the armature to drag on the field coil pole shoes and slow the speed down, and also create metallic dust inside the housing. Inspect the commutator bars for any evidence of burning on the edges- - - -that indicates a shorted winding that's making contact with the armature laminations. The bars I can see don't show any evidence of that problem.
New brushes and bushings, plus a new pedal switch should put it back in good shape for a long time to come. The best thing you can do to assure long starter life is keep the engine well-tuned so the starter doesn't have to run for very long each time it's used.
Thanks Jerry!
Crusing in the Passing Lane
That worn bushing, just a slight amount, will cause a lot of drag on the starter.
Ed
