0 members (), 118 guests, and 3 robots.
Topics128,196
Posts1,057,393
Members48,471
#1357280 04/26/2020 6:13 PM
Restoring a '57 3200 and trying to keep it totally stock throughout. When I bought it, it had a '56 (flat, not dished) steering wheel, not the dished one shown in '57 literature. Trying to figure out if any early '57s were made with leftover '56 steering wheels, or if someone changed it. It looked like it was all untouched when I took it apart, best I can tell. I actually like the '56 wheel better, so if it is original to the truck I'm going to keep it, but trying to be a purist and keep it stock. Anyone have any wisdom to offer on this? Thanks.
The very best nugget of wisdom anyone could ever offer you in dealing with your wife: You can be happy, OR, you can be right.
Whether you have flat or dished depends on whether you have the shorter or longer steering shaft. The dish distance was taken out of the length - 55.2 and 56 have longer shafts. Otherwise everything interchanges. I think you'd end up with the wheel in your chest if you used the longer shaft with the dished wheel... The opposite is also true - a flat wheel on the shorter shaft will give more room for a larger guy, so a 56 wheel in a 57 might be the reason you found what you did...
Sir Searchalot
Sir Searchalot
Don't think the leftover thing is viable.
If I remember correctly, when a flat wheel is put on a short shaft your fingers will hit the top of the dash when you turn the wheel...it's real close.
The turn signal bell and lever are also different between flat and dished wheels.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
J M Offline
To the best of my knowledge all 57 -59's had a dished wheel.
Possibly the whole steering shaft has been changed after an accident or a repair of some kind.
Jim
I'm putting a dished wheel on my 53 so I can have the turn signal mech. I had to shorten my column 4".
The shift lever also has a slightly different angle on the 57-59 vs the 55-56.
Fred
You could have used the 55/56 turn signal assembly as it was made for the flat wheel...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
