1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 131 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 131 | So I put a new water pump on my 216. I was advised not to use any gasket sealer but now there is a small drip coming from the bottom right bolt. Do you guys normally use gasket sealer or did I just not get it in exactly right? I ordered a new gasket but prefer to only do it once more. | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | sorry to hear about your leak, normal threads don't seal by design, so if a bolt going into any liquid i put some permatex onto it first. when i replaced my water pump i put a slick of that stuff everywhere, i don't think there is a particular reason not to, except it makes it more difficult to remove in the future perhaps there is other reasons, but mine works fine with goop -s | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | I always put Permatex Aviation Form-A-Gasket on water pump and t-stat gaskets...never had a gasket fail. Mike B  | | | | | Joined: Mar 2020 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 114 | WHAT Mike said, dont get crazy, let the gasket do its job, make sure the surface is clean an I just lightly coat my gaskets
woof359 Family 1952 3100 5 Window
