0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#1357324 04/27/2020 12:04 AM
' Offline
So I put a new water pump on my 216. I was advised not to use any gasket sealer but now there is a small drip coming from
the bottom right bolt. Do you guys normally use gasket sealer or did I just not get it in exactly right? I ordered a new gasket
but prefer to only do it once more.
'37 barn find #1357332 04/27/2020 12:37 AM
2 Offline
sorry to hear about your leak, normal threads don't seal by design, so if a bolt going into any liquid i put some permatex onto it first.
when i replaced my water pump i put a slick of that stuff everywhere, i don't think there is a particular reason not to, except it makes it more difficult to remove in the future
perhaps there is other reasons, but mine works fine with goop
-s
'37 barn find #1357333 04/27/2020 12:48 AM
I always put Permatex Aviation Form-A-Gasket on water pump and t-stat gaskets...never had a gasket fail.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
WHAT Mike said, dont get crazy, let the gasket do its job, make sure the surface is clean an I just lightly coat my gaskets
woof359 Family 1952 3100 5 Window
