4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
#1357272 04/26/2020 5:43 PM
Does the exhaust gasket (donut) go outside or inside? Everything online shows the gasket as 2-1/32. It looks like there is old gasket material inside the pipe, just doesn’t seem like that would do any good.
1963 C20, 292 (4.8L). 4-speed.
GeorgeCz #1357273 04/26/2020 5:50 PM
The donut sits inside the bell of the pipe. Be sure its sitting square when you tighten it up. Tighten evenly, warm engine up, then check the nuts again. You also might try to wire brush the manifold sealing face if you can to clean it up. John
GeorgeCz #1357287 04/26/2020 7:30 PM
Yup, the cleaner and smoother the surfaces are the better. Some pipes have a sleeve pressed into the pipe that holds the gasket square and makes it easier to mount and get a good seal.
38 Chevy 1/2 ton being resto-moded
65 AC Cobra replica
USAF vet
