3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1356926 04/24/2020 5:47 PM
Bonjour les bolters
The best solution to replace the old ingnition système by an eletronic ingnition système
For my 54 chevy 3100 6l 235cui
Merci From France
Alain
Moderator, Electrical Bay
Bonjour Alain,
Je prefere ce distributeur: https://www.ecwid.com/store/catalog/#!/Stovebolt-Mini-HEI-for-GM-216-235-261-&-GMC/p/1222040/category=18665949
Tres cordialement...
~ Jon
Great you the first who answer me in french .i will look after the item you indicate
Amitiés
Hi Texas
Alain, I Have been running one of those & works great. Only thing is it requires 12 volts, your rig is 6 volts unless it has been converted over to 12 volts at some time.
BC
1960 C60 pasture art
Pertronix (yes I know) makes a 6 volt negative and a 6 volt positive ground unit. About $130. Installs in about 45 minutes and you keep the points and condenser in the glove box if needed in and emergency.🛠
Originally Posted by Justhorsenround
Pertronix (yes I know) keep the points and condenser in the glove box when needed in emergency.🛠
Fixed it four you Martin!
BC
]Bonjour
My 54 has been converted over 12 volts whith négative to the chassis
What is the easyer way to replace condenser and points Whith a hei i’m débutant
Stayhome Alain
Alain, the Pertronix conversion is super easy and from the outside no one but you will know it’s electronic. There has been complaints from some on here that the unit was nothing but trouble but others have had many years of trouble free driving. Remove the points/condenser and associated wires. The igniter goes where the condenser was, using 1 or 2 screws. The 2 wires from the igniter exit the distributor through the hole where the original wire enters. Wiring is simple and easy. Put the rotor back on and the cap and fire it up. No gap to set. Regap your plugs and make sure you’re not using metal core plug wires. Happy cruising.🛠
I used an electronic unit inside the stock distributor on a 283. worked great
Another quality post.
Real Trucks Rattle
Bonjour Alain,
L'utilisation du distributeur de Langdon est facile et il ressemblera presque exactement a l'unite d'origine. Cependant, vous aurez peut etre besoin un fil de gros plus calibre (entre le contacteur d'ignition et le distributeur HEI). Mais meme cela est tres simple. Il a ete mentionne ici que Pertronix a eu des problemes. Personnellement, je pense que ce n'est pas bon. Trop d'entre eux cessent de fonctionner.
Ok, in English...Using the Langdon distributor is easy and it looks like the original unit. You may need to install a larger gauge wire from your ignition switch to the distributor but this is very easy. It has been mentioned here that the Pertronix has problems. Personally I think these units are not good. Too many of them cease to function. As one more comment: I have the Langdon distributor. It is a conversion of another GM distributor and parts are available. I hope my use of the French language will not upset the Academie Francaise. Maybe it will give them some humor. The last time I saw them (in 1997) two of them were smoking too much.
~ Jon
Hi
Pertronix orLangdon is there a third solution that everyone agrees 😉
Have a nice 1st Mai
Crusing in the Passing Lane
HEI works fine, no ignition resistor, 10 or 8 gauge feed wire.
Ed
Sir Searchalot
Sir Searchalot
Wouldn't just a GM HEI have dropped right in?
What exactly did you do? Built in coil or external? Are you saying you used a Pertronix?
"Pertronix or Langdon is there a third solution that everyone agrees 😉"
headscratch
You will not find consensus agreement on this question/topic, Alain.
Happy May Day
Sir Searchalot
Sir Searchalot
The first solution to a non problem is: stay with original points. Second and third is Langdon, Pertronix.
First: original points 6v ($30 - Distributor Cap, Distributor Rotor, and Premium Spark Plug Wires; 6v coil $10)
Second: Pertronix 6v ($130 - use original coil or 6v coil $10)
Third: Langdon 12v ($222 w/coil and ignition wires)
Sir Searchalot
Sir Searchalot
As said, "You will not find consensus agreement on this question/topic"
I ´v mechanic Friend searching solution with litle electronic box without changing nothings except electrical connection
When i get this solution i give you some news
Thanks for yours answers
Deve has an hei conversion.
http://devestechnet.com/Home/HEIgnition
Mike
$185 - $350
Of course, just in case, carry a set-up spare standard distributor
(Rockauto: $89 plus returnable $100 core-charge - plus shipping both ways : or, carry you old distributor as a spare)
Brand new GM HEI set up for 216/235/261 on Ebay- - - - -$114.99- - - - -no core charge! When it smokes the offshore module that's in it, buy an OEM GM item at the local parts store!
What would be the OEM GM part number for use at the local parts store?
There is a GM Fits Toyota HEI Complete BLK Distributor 65K Coil Straight 6 194 216 235 261 on eBay for $85 and free shipping. eBay link
Any 4-pin HEI module from the mid-1970's to the early 1980's before Electronic Spark Control came out- - - - -they're all the same. If you need to change the pickup coil it would have to be one for an even-fire V6 or an inline six like a 250 or 292, etc.
Would this get me the part a local parts store:
"Any 4-pin HEI module from the mid-1970's to the early 1980's before Electronic Spark Control came out- - - - -they're all the same. If you need to change the pickup coil it would have to be one for an even-fire V6 or an inline six like a 250 or 292, etc."
Tim,
It would depend who is standing on the other side of the counter. If it's some kid that only knows how to push bottons on a keyboard , all it would get you is a blank stare. If it would be someone that had been selling parts for 10yrs, it would probably get you what you needed.
Or you could just tell them you need an HEI module for a 1976 chevy nova with a 250 cu.in. 6 cyl engine.
Tommy
59 apache 1/2t
261 short stepside
Thanks, Tommy
My ignorance of HEI is showing.
If for some reason I ever used a HEI unit, I'd carry a spare stock distributor, or I'd carry a spare module and/or a spare HEI distributor (if I took long trips).
I've been running HEI's in most of my vic's for the past 30+ years. The only failure that I had was a 200,000+ miles standard points distributor on a 250.
Real Trucks Rattle
Deve HEI conversion seems to be complicate to install but an achieved project
Do you know guys abble to do this conversion(modifie reluctor)
Tim do you have reference for a new electronic distributor which fit in my 235
To carry the old points condensor as a spare
Très bonne idée
Amitiés
Alain
Before my last post i did’nt saw yours answers
France jet lag🤣
What do you think about HEI that Tim find
Do you think à knew complete HEI coil distributor like that is better than a HEI module fit in the old stock distributor
The EBay sold complete replacement HEI distributors are an easy swap allowing you to keep your original distributor as an emergency spare. The only problem I found when doing the swap on a ‘62 235 was close tolerances with the block. Didn’t have to make it fit it just fit close. Good luck.🛠
Been running a mini HEI from Langdon's for several years, works great. I take long trip, last fall the wife & I put about 1,200 miles on a trip up into BC Canada, runs like a champ.
http://www.langdonsstovebolt.com/store/online-catalog/#!/Stovebolt-Mini-HEI-for-GM-216-235-261-&-GMC/p/1222040/category=18665949
I run plug wire to fit a later Ford 300 L6 & platinum AC Delco #7 plugs (gm p/n: 19360569).
BC
Excuse me I don’t understand the problem you found
Adjustment is difficult to realize ?
I’ve a 54 235ci
The distributor cap was within 1/16 inch of the block when installed. Those systems use the GM large cap not the small cap like Langdon’s unit.
The real HEI fits. If it contacts the side cover or the block, a little careful grinding of the edge of the distributor cap or the block might be required. Stay FAR away from that conversion unit that uses the original distributor and some sort of cobbled-up adapter for an obsolete Chrysler Corp. trigger unit and a GM module.
Hotrod Lincoln pix
Yes, the large housing distributor will fit- - - -I have installed several of them. The main body of the distributor rises considerably higher above the block than the original housing, and there's just enough room for it to clear the engine properly. The inexpensive ones sold on Ebay are made overseas, and I don't trust the electronic parts in them. OEM General Motors modules and pickup coils fit, and swapping to them makes me have a lot more faith in their reliability.
To jerry
Can you give a complete reference for the OEM general motor complete distributor
Alain
Any HEI distributor for a 250 or 292 cubic inch inline six cylinder engine from the mid-1970's to the mid-1980's can be adapted to fit a 216, 235, or 261 engine by machining the large diameter mounting flange on the housing away and fabricating a sliding clamp to allow it to be positioned properly for the drive gear to engage the camshaft and the oil pump correctly. That is all the vendors of those HEI units do to "adapt" them from their original application. Posting Ebay links on a general discussion forum thread is discouraged by the moderators in the PC Patrol, so I will be glad to forward a few links to you by private message. I've been doing my own conversion machining on both the large diameter distributors and the ones sold by Langdon's for several years, with zero issues where reliability or fit is concerned.
The photo of the HEI distributor you posted is one of the 250/292 items that has been modified to fit the early Chevy engine. The early inline six engine in the Toyota Land Cruiser was a virtual clone of the Chevy 235 engine, made under license from GM, I believe.
