1 members (TUTS 59), 95 guests, and 1 robot.
Topics128,115
Posts1,056,624
Members48,450
Just rewired my 47 panel, replaced light switch with new. The rheostat is heating up to almost burning the contact when light switch is on. Didn’t do this at first. I’m installing a turn signal and in process of wiring the tail lights. It’s 6 volt. Any ideas?
1949 Chev 3800
Was the new light switch for 12V? Both are available, and it might make a difference in how hot the rheostat gets. It will always get warm, as it's a resistance device, but operating a 12V rheostat on 6V could be the cause.
Insomniac
Insomniac
Yes, the rheostat is a variable resistor. The more current that passes through it, the hotter it gets.
I have not been happy with the rheostat in my truck. (I have also found them troublesome in other older cars). To me, "rheostat" may be a curse word in some foreign language. In this truck, I thought I had it working OK, but last time we were out in the evening, I turned the lights on and there were no instrument lights. Turning the rheostat madly back and forth did not clean the contacts and bring the lights up. I couldn't find a sweet spot where the instrument lights lit up so we drove home without them. Next day, I moved the instrument light wire under the same screw as the tail lights. So now the instrument lights are not adjustable, but they work.
My solution is to simply connect the instrument light wire to the same point on the light switch as the tail lights. Who needs a rheostat!
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Good info Gord.
RHEOSTAT!! Nope, the forum censor doesn't flag it. grin
The dash lights should not draw enough current to heat that up. Something is wrong in the setup.
1951 1 Ton Completed
Check the dash light circuit for a short- - - -there shouldn't be enough current draw to make the stat get that hot.
Ok, thanks for all this information guys. I will retrace everything. The switch I have is supposed to be a replacement for the original 6 v switch. I assumed it was 6v. I do like the idea of bypassing the dash light terminal. I don’t care to or have need to dim them anyway. Thanks again!
1949 Chev 3800
