2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1356623 04/22/2020 7:51 PM
I
I Offline
hello,so ive posted about my engine before,just bought this truck a few weeks ago(1946 gmc 1/2 ton) with what I was told was a 228 engine but thinking its a 236 by the number stamped behind the distributor
anyway my question is are the distributors all the same ?,I decided to check out the timing and found the vacumn advance must be no good,i put a manual vacumn pump on it and can not get it to move
thanks for any help
WILLIAM A GOVE
Take the cap off and look at what delco numbers are on the point plate and post back.
Mike
I
I Offline
I don't see any numbers,it looks as though the point plate may have been replaced
WILLIAM A GOVE
That’s a first for me. I have never seen a blank plate.
Mike
Early GMC distributors usually have a tag on the outside and are not stamped on the points plate.
My Blog
I learn something new here every day! Dave, would the point plate be completely devoid of any markings at all?
Mike
That is my recollection.
My Blog
Insomniac
Insomniac
If all you need is a new vacuum advance unit, this looks like it's universal...
https://www.classicparts.com/1937-62-Vacuum-Advance-Stud-Type-6-Cylinder/productinfo/83-274/#
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I
I Offline
thank you Gord I think ill give that a shot
WILLIAM A GOVE
